Evolution
Aug 21, 2023Follower
GS752TPv2 VLAN
I am trying to setup VLAN's but I seem to be missing something. I would like to setup a voice VLAN so that my voice traffic can have priority over the data traffic. I can't seem to get the default ...
schumaku
Aug 21, 2023Guru - Experienced User
Not sure what advantages you expect. Assuming all VoIP and Internet data is going into the very same connection, differentiating data and voice does not bring any advantagees in my opinion. Even 7d marking the voice traffic different, no other routing or dedicated VoIP connection can take any preferences.
ErwinL
Aug 30, 2023NETGEAR Moderator
Hi Evolution,
Have you checked this article, the UI might be a bit different in appearance but it should be the same with your switch UI?
Have a lovely day,
Erwin
Netgear Team
