sistematico_17's avatar
Jul 19, 2022
GS752TPV2 voice and data on same port
Hello,
I've tried every possible combination of tagged, untagged, and PVID and can't get the voice and data to work over the same port.
My voice and data are on the same VLAN 1. Is a small office, so no biggie. We added VLAN 30 for the IP cameras, and for some circumstances, we are forced to use a single port for a camera and a VoIP phone.
How can i configure this port to get both the phone and camera to work?
Thanks
  • schumaku's avatar
    schumaku
    Voice and data is on the same VLAN 1, so it's the same network, same everything, isn't it? You need to avoid the OID does put in place OID specific VLAN (like Voice).
    • sistematico_17's avatar
      sistematico_17
      Yes, Voice and data are on the same VLAN 1. However, for this one specific port, I need to connect a Phone that uses VLAN 1 and a Cameras that uses VLAN 30.
      What changes do i need to make to get that working? Thanks
      • schumaku's avatar
        schumaku
        What does stop you? Keep the VLAN 1 config, just add the VLAN 30 tagged, configure the camera LAN 30 tagged. And then the other areas of the switch and network where you need to carry this VLAN 30 of course.
ProSupport for Business
