fredbeligolo
Feb 21, 2019Aspirant
GS752TXP Protection IP Rating
What is the Protection IP rating of GS752TXP ? Is there any reference for this. Thanks
- Feb 22, 2019Hi, thanks for your message.
IP (or "Ingress Protection") ratings are defined in international standard EN 60529 (British BS EN 60529:1992, European IEC 60509:1989). They are used to define levels of sealing effectiveness of electrical enclosures against intrusion from foreign bodies (tools, dirt etc) and moisture. NETGEAR switches are not designed for any IP Rating compliance. NETGEAR switches are designed for standard office use. Hence no IP Rating of any sort.
I hope this helps,
fredbeligolo
Feb 22, 2019Aspirant
Thanks for the reply.
yes im talking about the installation environment, we have the same thought of IP rating for this device (IP31).
However, what im looking for is a paper/actual document stating the IP rating.
LaurentMa
Feb 22, 2019NETGEAR Expert
I hope this helps,
I hope this helps,
