RobLigt
Oct 16, 2022Tutor
GS752TXS bricked due to firmware-update?
Hi, In our continues efforts trying to be green we are still repurposing our NG switches; A GS752TSX had an older firmware running so we downloaded the latest one, followed the outlined NG procedur...
DaneA
Oct 16, 2022NETGEAR Employee Retired
Let us try to perform a factory reset on your GS752TXS and observe if it will boot up properly.
If still the same problem after doing a factory reset, I suggest you to open a support ticket with the NETGEAR Support Team at anytime here for further hardware check. If the switch has been declared faulty, be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of your GS752TXS for warranty verification. If the hardware warranty is still valid, an online replacement will be processed.
DaneA
NETGEAR Community Team
RobLigt
Oct 24, 2022Tutor
Yes, it is indeed bricked, no reset brings it back to life.
And that simply because of a firmware-update where NG neglected to warn (anywhere!) to do updates in incremental steps. (if your current version is too old)
Very unfortunate that despite this being a very likely occurrence if not careful (when dealing with switches collecting dust and probably having very old firmware). there is no warning about this issue anywhere except a mention once (now twice) on this Community?
Getting the paperwork is too much hassle, I guess I will need to scrap this one.
Such a waste as we re-use these for schools & ngo's.
