tommymaguire's avatar
tommymaguire
GS752TXS device view
Hi, has anyone managed to solve the device view issue with these switches, its a bit of a minefield. If there is no direct resolution does anyone have a workaround, thanks
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    Hi tommymaguire,
    What's the firmware version of the GS752TXS?
    I suggest updating it to its latest firmware (v6.1.0.39) to see if that resolves the issue.
    Firmware file and instructions are here.
    JeraldM
    NETGEAR Community Team
    • tommymaguire's avatar
      tommymaguire
      I had already upgraded it to  firmware (v6.1.0.39), people seemed to indicate its a java issue, is this correct?
      Thanks
      • schumaku's avatar
        schumaku
        Several older switches Web UI are not updated towards a HTML5 device view - the Java based one is inop, the the Applet API should be drpreciated for removal. It is essentially irrelevant since all web-browser vendors have either removed support for Java browser plug-ins.
ProSupport for Business
