Thirty7
Feb 17, 2021Aspirant
GSM7352sV2 no ACL out
No abiltiy to ip access-list namehere vlan ## out.... It's in the CLI guide. Is this straight up a bug?
DaneA
Mar 09, 2021NETGEAR Employee Retired
What is the current firmware version of the GSM7352Sv2? If ever its not yet on the latest version, kindly update it. The latest GSM7352Sv2 firmware is v10.0.0.53 and you can download it here. Then, check if the same problem will be encountered.
DaneA
NETGEAR Community Team
- Thirty7Mar 09, 2021Aspirant
It doesn't much anyways as I replaced with an HPE ProCurve and extended ACL's are working in the needed directions.
Looks like the forum sofware won't upload my .png screen shot.
GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.35
