robfantini's avatar
robfantini
Auto VoIP on gsm7352sv2
Hello
 I've got some questions regarding auto voip on our switches.  Product Name : GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.35
The documentation and switch do not seem go together.
so from cli this is supposed to work per 7000_series_SWA_8.0.3_1Nov10.pdf
 (Config)# auto-voip all
% Invalid input detected at '^' marker.
however these are the avail options:
(Config)#auto-voip ?
oui                      Configure auto VoIP OUI
oui-based                Configure OUI based auto VoIP
protocol-based           Configure call control protocol based auto VoIP
vlan                     Configure auto VoIP VLAN
Could someone direct me to the correct documention for our switch?
thanks
  • Retired_Member's avatar
    Retired_Member
    May 07, 2017
    Hi robfantini,
    Welcome to the community! Smiley Happy
    As your switch model is M5300-52G3(GSM7352Sv2h2) with firmware is v10.0.0.53. I suggest you reference to CLI User Manual of below link (Page508: Auto VoIP). It is admin guide for software Version 10.x.
    For more detailed information about M5300-53G3 switch, please reference to link.
    Hope it helps!
    EricZ
    NETGEAR employee
  • Note this is at end of that last post: 'Model: M5300-52G3 (GSM7352Sv2h2)|ProSAFE '
    it is not a 'h2' just 'GSM7352Sv2'   .   I assume those are different models.
      Retired_Member
      Hi robfantini,
      Hope it helps!
      EricZ
      NETGEAR employee
ProSupport for Business
