robfantini
May 05, 2017Aspirant
Auto VoIP on gsm7352sv2
Hello I've got some questions regarding auto voip on our switches. Product Name : GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.35 The d...
- Retired_MemberMay 07, 2017
Hi robfantini,
Welcome to the community!
As your switch model is M5300-52G3(GSM7352Sv2h2) with firmware is v10.0.0.53. I suggest you reference to CLI User Manual of below link (Page508: Auto VoIP). It is admin guide for software Version 10.x.
For more detailed information about M5300-53G3 switch, please reference to link.
Hope it helps!
EricZ
NETGEAR employee
robfantini
Note this is at end of that last post: 'Model: M5300-52G3 (GSM7352Sv2h2)|ProSAFE '
it is not a 'h2' just 'GSM7352Sv2' . I assume those are different models.
Retired_Member
May 07, 2017Hi robfantini,
Welcome to the community! ![]()
Hope it helps!
EricZ
NETGEAR employee
- robfantiniMay 08, 2017Aspirant
thank you that does help.
- robfantiniMay 08, 2017AspirantI'll open a new thread and may need to fill a bug report for this: I started out using oui based auto-voip. when I changes to protocol based the stack frooze. after restart only on of the 2 switches in the stack had link lites lit on the 20 interfaces in used. beware of changing auto-voip modes.
- Retired_MemberMay 08, 2017
Hi robfantini,
It's a pleasure to help you!
Ok, for your new question, does it mean the stack member will freezing when changing auto-voip mode from OUI-based to Protocol-based?
Is the unit not working? All ports is down? Could you please provide more detailed information?
Actually, the Switch support enable OUI-based and Protocol-based in Auto-VoIP configure page at the same time, no need change the mode.
EricZ
Netgear Employee
