robfantini
May 08, 2017Aspirant
changing auto-voip type broke stack
I had a stack of two of these:
!System Description "GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.35"
!System Software Version "10.0.0.53"
early today I set up ' auto-voip vlan '
after trying to switch to 'auto-voip protocol-based' the stack froze.
after power reset the former master unit has no link lites lit.
the former secondary is runnig OK as master.
from prosafe web page , the bad switch is seen. some of the vlan tags are not what they are supposed to be [ some T's changed to U ]
Does someone have a suggestion to fix the broken unit?
tech support by email told me how to solve this.
from cli: reload
As expected the switched restarted so office was ready for that.
- robfantiniAspirant
More info:
before changing the auto-vlan type , I had saved the running config to start up , along with saving the text settings to tftp.
the one remaining switch is running good - all vlans report working phones, printers and workstations.
ALSO from java/web device view - Back of switch : Only the working switch shows a stack connection slot green. Power and serial are green on both
- Retired_Member
Hi robfantini,
Welcome to the community!
Could you please answer below quesitons, we need more detailed information for further analysis:
1. What's the auto-voip VLAN ID? Is it a new created VLAN or exsit VLAN?
2. Could you provide the auto-voip CLI command that you execute?
3. It's will be better if you can provide us the configuraiton of the Switch.
How do I send configure files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/3143
9 Regards,
EricZ
NETGEAR Employee
I am now using 'protocol based' . there is no vlan setting needed for that.2. Could you provide the auto-voip CLI command that you execute?
no auto-voip vlan auto-voip protocol-based
http://kb.netgear.com/app/answers/detail/a_id/31439
I'll send the config file next.
