robfantini
May 08, 2017Aspirant
changing auto-voip type broke stack
I had a stack of two of these: !System Description "GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, 01.00.35" !System Software Version "10.0.0.53" e...
- May 09, 2017
tech support by email told me how to solve this.
from cli: reload
As expected the switched restarted so office was ready for that.
Retired_Member
May 08, 2017Hi robfantini,
Welcome to the community! ![]()
Could you please answer below quesitons, we need more detailed information for further analysis:
1. What's the auto-voip VLAN ID? Is it a new created VLAN or exsit VLAN?
2. Could you provide the auto-voip CLI command that you execute?
3. It's will be better if you can provide us the configuraiton of the Switch.
How do I send configure files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/3143
EricZ
NETGEAR Employee
robfantini
I am now using 'protocol based' . there is no vlan setting needed for that.
no auto-voip vlan auto-voip protocol-based
http://kb.netgear.com/app/answers/detail/a_id/31439
I'll send the config file next.
- Retired_MemberMay 08, 2017
Hi robfantini,
Thanks for your immediately response.
Could you please also send us the tech-support file at the same time with the configuration file. We can check the detailed information for the freezing Unit.
- robfantiniMay 08, 2017Aspirant
I am unable to generate a tech support file.
I get this error: Error! File is either empty or not found.
I tried http and tftp .
Is there another way to create the file?
- Retired_MemberMay 09, 2017
Hi robfantini,
You need execute command as 'show tech-support' by CLI mode(console port or telnet) at first, it will generate tech-support file.
1- I sent the startup-config in an email.
2- another thing I did after the two cli commands, from web page at OUI Port Settings - I disabled Auto VoIP Mode for all ports.
