darkcloudi
Jan 10, 2024Guide
GSS108EPP - POE connecting with X50-POE
So I have had the GSS108EPP for a few years and decided to get my first POE device a Deco X50 POE, so I tried to connect this to either of the first 4 ports which supplies Poe but the poe device is n...
- Jan 12, 2024
New switch now showing the following, so a replacement resolved my issue:
Enable
Low (Port Priority)
802.3at (Power Mode)
User
30.0 (Power Limit)
IEEE 802
Class4
53 (Output Voltage)
128 (Output current)
6.9 (Output Power)
25 (Temp)
Delivering Power (Status)
No Error (fault status)
Thank you schumaku for your help and advise.
schumaku
Jan 10, 2024Guru - Experienced User
darkcloudi wrote:
...I have tried directly with a Cat 6 or 5e cable (so a short cable), is there something that needs to be setup to get Poe to start up or should it work out the box?
All four pairs correctly patched and workable?
darkcloudi wrote:
so should work?
Yes.
darkcloudi wrote:
Port Port Power Port Priority Power Mode Power Limit
TypePower
Limit (W)Detection Type Class Output
Voltage
(Volts)Output
Current
(mA)Output
Power
(W)Temperature Status Fault
1 Enable Low 802.3at User 0.0 IEEE 802 Unknown 0 57617 0.2 58768 No Error
Output voltage and power indicated very wrong. Some problem with the PoE handshake, the PoE controller on the switch.
GSS108EPP firmware version?
Attempted a factory reset of the switch already?
If nothing helps, please head to https://my.netgear.com/ ... select your GSS108EPP serial number ... and follow the [Request Hardware Support] process.
More a curiosity question to exclude a possible hardware issue: An external power supply (I assume there is a more or less standard power plug) does allow to operate the X50?
- darkcloudiJan 10, 2024Guide
Thanks for the response, i'm using Belkin cables so hoping there patched properly (also tried one that came with the X50 Poe device so a none Belkin ethernet cable)
Firmware for the switch is: V1.0.0.22 (so latest)
The X50 comes with a standard power supply and have got it working with that, thought lets see if the Poe works, as trying to refrain of adding another power plug.
Haven't tried a factory reset so will backup my settings and see if that helps. Thanks
So went into the maintenance menu and factory default but the poe configuration seems to be the same as per my first thread. No power going into the X50 Poe device.
Will raise a request with Netgear, currently struggling as getting "The chat queue is busy right now. Try again soon" but will see if they can provide any advise once i get through.
thanks again
Those guys at Netgear were able to troubleshoot, appears a faulty poe module 😞 so hoping to get the device replaced, just waiting on stock and hopefully get a replacement soon
