darkcloudi's avatar
Jan 10, 2024
GSS108EPP - POE connecting with X50-POE
So I have had the GSS108EPP for a few years and decided to get my first POE device a Deco X50 POE, so I tried to connect this to either of the first 4 ports which supplies Poe but the poe device is n...
  • darkcloudi's avatar
    darkcloudi
    Jan 12, 2024
    New switch now showing the following, so a replacement resolved my issue:
    Enable
    Low (Port Priority)
    802.3at (Power Mode)
    User
    30.0 (Power Limit)
    IEEE 802
    Class4
    53 (Output Voltage)
    128 (Output current)
    6.9 (Output Power)
    25 (Temp)
    Delivering Power (Status)
    No Error (fault status)
    Thank you  schumaku for your help and advise.
ProSupport for Business
