refraingott
Aug 07, 2018Aspirant
GSS116E unable to upgrade firmware from 1.0.0 to any available firmware
Hello,
I was trying to update my Netgear GSS116E switch from firmware version V1.0.0.0 to the current version (as of this time, this seems to be V1.6.0.5).
Since the support pages already stated ...
- Aug 09, 2018
Hi JohnCarloV,
I've actually read that post before I created mine, and I also tried using netsh/arp to add the IP of the switch to my arp table, but that didn't change a thing, sorry I didn't mention it.
What I actually did try after re-.reading the post you mentioned was to push the firmware from a Raspberry Pi3 running Linux to the switch via tftp.
The Linux box managed to send the whole file, however it took 2 firmware resets and a couple of power cycles to make the switch's GUI reappear again afterwards.
Nevertheless, it was a success though, firmware 1.6.05 had been installed, and the GUI asked immediately for the 1.0.0.5 boot loader file, which is now also successfully installed.
So, in my case, the solution was just not to use ProSafe, but to use a command line tftp client instead, as JohnRoe had suggested in his post..
Case closed, thank you and thanks to JohnRoe.
refraingott
JohnC_V
Aug 08, 2018NETGEAR Employee Retired
Hi refraingott,
Welcome to our community! :)
It seems that this could be a known issue. May you be able to try the steps on these thread? By adding the IP and MAC address of your PC to the ARP table so that it could be known inside the network.
refraingott
Aug 09, 2018Aspirant
Hi JohnCarloV,
refraingott
