No4
Aug 28, 2019Tutor
Having trouble implementing vlan on Prosafe switch
I'm in the process of slowly upgrading my home network. I originally aquired the Prosafe JGS524PE switch for the POE capabilities for my security cameras. Now I'm trying to ditch the ISP supplied H...
- Sep 05, 2019
OK, trunking problem solved, although I'm confused as I'm sure I'd already tried those settings with no success. The switch was fine, but I needed to add vlan3 as a PVID for Eth2 on the ERX. Now I can plug into port 16 and get assigned a vlan3 address from the ERX DHCP server. If I change a port to vlan4, the same applies. I can login to the camera on port12/vlan8 so the firewall settings are working also. Here is a pic of the ERX settings to clarify for anyone else dealing with similar issues. Thanks for the help all.
DaneA
Aug 29, 2019NETGEAR Employee Retired
No4,
Welcome to the community! :)
I'm not familiar with both Ubiquiti Edgerouter X and UniFi AP-AC Lite. However, kindly answer the questions below:
a. Are VLANs also configured on the Ubiquiti Edgerouter X?
b. What is the IP address of the laptop when connected wirelessly to the UniFi AP-AC Lite?
c. Is the UniFi AP-AC Lite connected to the Ubiquiti Edgerouter X or directly connected to the JGS524PE switch?
d. Is the wireless network broadcasted by the UniFi AP-AC Lite tagged to a certain VLAN? If yes, to what VLAN?
e. What is the current firmware version of the JGS524PE switch?
It would be best if you post a detailed diagram of your existing network.
DaneA
NETGEAR Community Team
- No4Aug 30, 2019Tutor
Thanks for the response.
a. Yes, VLANs are configured on the ERX ports 2-4. This has been tested by plugging the laptop into eth3. This would result in an ip address of 192.168.3.x. If I configured the laptop's eth adapter to vlan 4, I would get an ip address of 192.168.4.x, and similarly for vlan 8.
b. When connected to the APAC Lite, the laptop ip address was 192.168.3.47.
c. The APAC Lite is directly connected to the ERX on eth4.
d. The APAC broadcasts 3 wireless networks. The default home network as above, and vlans 6 & 7 for guest network and wireless IOT.
e. The switch firmware is 2.0.1.26.
Network diagram attached.
