No4's avatar
No4
Tutor
Aug 28, 2019
Having trouble implementing vlan on Prosafe switch
I'm in the process of slowly upgrading my home network.  I originally aquired the Prosafe JGS524PE switch for the POE capabilities for my security cameras.  Now I'm trying to ditch the ISP supplied H...
  • No4's avatar
    No4
    Sep 05, 2019
    OK, trunking problem solved, although I'm confused as I'm sure I'd already tried those settings with no success.  The switch was fine, but I needed to add vlan3 as a PVID for Eth2 on the ERX.  Now I can plug into port 16 and get assigned a vlan3 address from the ERX DHCP server.  If I change a port to vlan4, the same applies.  I can login to the camera on port12/vlan8 so the firewall settings are working also.  Here is a pic of the ERX settings to clarify for anyone else dealing with similar issues.  Thanks for the help all.
ProSupport for Business
