spotlizard
Dec 13, 2023Aspirant
Home Network VLAN Question
Hi, I have a question regarding my current home network and if it may be possible to create VLANS. I have a pretty traditional 'flat' home network structure in my townhome. I have ethernet jacks...
schumaku
Dec 14, 2023Guru - Experienced User
No way to implement VLAN based segregation without the help of multiple IP subnetworks.
spotlizard
Dec 14, 2023Aspirant
Ah, I'd wondered about that so thank you so much for affirming.
Looking at the router manual for the RT-89AX there doesn't seem to be an easy way to set up subnets. It may be easier just to invest in a Layer 3 switch but that's probably more money than I want to spend right now.
Thank you so much for the quick reply.
