Chucklesuk
Jan 10, 2024Initiate
How do I connect two switches
I have two XS508M 10gb switches. Can someone please tell me the best way to connect either together or direct to router. Do/can I connect the two switches together or should I run two independent c...
Chucklesuk
Hi thanks for reply.
When l mentioned other kit l mean Hive control for central heating etc and another hub for home lighting control (Phillips Hue). When l added the second switch which was connected in series if you like then with another port connected to the router the two hubs would not work/connect. However when l connected the hubs to the other identical switch all worked ok. That seemed strange to me.
I will try two lines from router to each switch as soon as l make up a new cable.
Regard to speeds no idea what the router gives but as l said both switches 10gb also the Nas drives on my network. The connected pc l just finished building is only 2.5gb motherboard as no spare slots for a 10gb card as used in my old scrapped pc. So a mixture of speeds.
But my main question is should l connect each switch individually to the router or just loop them together with one line to router?
Hope your crystal ball has a good holiday. Lol
Thanks again
schumaku
Jan 10, 2024Guru - Experienced User
Installing a new line does make sense only if the router does have two or more 10 GbE ports ... unless you are on a very new BT Business platform (e.g. using the Meraki MX75) very unlikely.
