cwebster
Oct 12, 2015Aspirant
How do I constrain multicast traffic to specific ports on GS716Tv3?
I can't find specific instructions to constrain multicast traffic on the GS715Tv3 smart switch. I need to force all multicast traffic to travel over a specific set of interfaces, or at least to s...
- Oct 22, 2015
To switch the the Mangement VLAN to 4.
Make sure you have 2 ports on the switch, one in VLAN1 one in VLAN4.
Set the system you are using to a static IP in the range of the switch and confirm access to the web config then change the "Management VLAN ID" to 4 and Apply. then switch the system you are using to the port or any port in VLAN 4 then you should have access, if not, wait about 60-90sec and try again becuase you may have STP on and it will block anything on the port for a bit unless its set to "Fast Link" Enabled.
Then under "IP Configuration" set the switches IP address to somthing in in IP range of VLAN4.
For Simplisicty sake, Untagged ports should only ever be in 1 VLAN at a time.
And instead of using the point and click, goto "Port PVID Configuration" and just set the VLANs there.
Set PVID and VLAN member the same for a port, based on what VLAN it needs to be in
And to confirm, do you have a cable going from switch to switch for each VLAN? You could cut down on cables and ports if you trunk/tag the ports to the next switch. then all 3 VLAN would only need 1 cable between each pair of switches, saving you atleast 4 ports on each switch.
Just an example from my GS724T (ignore ports g8 and g19-20, thier Current PVID is becuase of somthing else you are not doing, LACP and Span/Monitoring):
All ports are setup for a single VLAN, my "Main LAN" is VLAN12, which the mangement VLAN is set for aswell, ports g23-24 are VLAN Trunks, they are set to tagg VLAN12 and 14 when that traffic goes out of those ports, then the switch on the other side reads the tagg and acts acordingly, this way I dont need 2 cables/ports for each of those.
DaneA
Oct 13, 2015NETGEAR Employee Retired
Hi cwebster,
Have you already came across with these articles below? It might help you with your concern:
Hope it helps. Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
- cwebsterOct 13, 2015Aspirant
Thank you Dane. I think that's the part I was missing, about having to have a router to manage the multicast group membership. I'll try that when the systems are available again today.
First, however, I'm going to try renaming the vLANs so they don't all match. I'm not quite sure whether the multicast traffic is being forwarded between switches because of the identically named vLANs or because the switch automatically forwards all multicast traffic to all vLANs on the local switch. The one vLAN that's connected to all switches would then distribute the traffic to all. Can you clarify this behavior?
Best Regards,
Cal Webster
- DaneAOct 13, 2015NETGEAR Employee Retired
Hi cwebster,
With regard to this, if multicast traffic is being forwarded to all VLANs then it is not multicast at all. That would be broadcast.
Kindly refer to the first link I have provided to you. :smileyhappy:
DaneA
I don't know if it's being forwarded to all vLANS Dane. All I know is that there are multicast packets (multicast addr 225.0.0.250) from [IOSubsystem1] on one switch being forwarded to [IOSubsystem2] on a separate switch. The only thing physically connecting these two switches is cable from each one's [SimvLAN] going to the [SimvLAN] on a separate development lab switch. See illustration below. When I pull the plug on the development network connection, the data stream corruption ceases - packets are no longer forwarded.
[Switch 1|I/OvLAN1]->[LinuxHost1]
[Switch 1|I/OvLAN1]->[IOSubsystem1]
[Switch1|SimvLAN]
[Switch9|SimvLAN]----------------->[DevHost]
[Switch2|SimvLAN]
[Switch 2|I/OvLAN2]->[LinuxHost2]
[Switch 2|I/OvLAN2]->[IOSubsystem2]
I have configured an IGMP Snooping Querier on one of the GS716Tv3 switches [Switch1]. I used IP address 192.168.55.100 for the querier address, an available address from the network on the affected vLAN.
In "Querier vLAN Configuration" I added vLAN 6 [IOvLAN1], the affected vLAN.
Then in "IGMP Snooping vLAN Configuration" I added vLAN 6 [IOvLAN1].
I'm not sure where to go from here, though. It looks like everything I've done up to now is geared toward identifying and tracking multicast traffic. How do I actually tell the switch to keep its multicast traffic ONLY on the 3 ports that comprise vLAN 6 [IOvLAN1]?
Thank you for your help!
Cal Webster
