cwebster
Oct 12, 2015Aspirant
How do I constrain multicast traffic to specific ports on GS716Tv3?
I can't find specific instructions to constrain multicast traffic on the GS715Tv3 smart switch. I need to force all multicast traffic to travel over a specific set of interfaces, or at least to s...
- Oct 22, 2015
To switch the the Mangement VLAN to 4.
Make sure you have 2 ports on the switch, one in VLAN1 one in VLAN4.
Set the system you are using to a static IP in the range of the switch and confirm access to the web config then change the "Management VLAN ID" to 4 and Apply. then switch the system you are using to the port or any port in VLAN 4 then you should have access, if not, wait about 60-90sec and try again becuase you may have STP on and it will block anything on the port for a bit unless its set to "Fast Link" Enabled.
Then under "IP Configuration" set the switches IP address to somthing in in IP range of VLAN4.
For Simplisicty sake, Untagged ports should only ever be in 1 VLAN at a time.
And instead of using the point and click, goto "Port PVID Configuration" and just set the VLANs there.
Set PVID and VLAN member the same for a port, based on what VLAN it needs to be in
And to confirm, do you have a cable going from switch to switch for each VLAN? You could cut down on cables and ports if you trunk/tag the ports to the next switch. then all 3 VLAN would only need 1 cable between each pair of switches, saving you atleast 4 ports on each switch.
Just an example from my GS724T (ignore ports g8 and g19-20, thier Current PVID is becuase of somthing else you are not doing, LACP and Span/Monitoring):
All ports are setup for a single VLAN, my "Main LAN" is VLAN12, which the mangement VLAN is set for aswell, ports g23-24 are VLAN Trunks, they are set to tagg VLAN12 and 14 when that traffic goes out of those ports, then the switch on the other side reads the tagg and acts acordingly, this way I dont need 2 cables/ports for each of those.
