noisydude
Mar 30, 2021Aspirant
How to configure switch GS108PEv3 with multiple VLANs on a single port
I was hoping someone could point me in the right direction. I believe the issues I am seeing on my network are related to the way I setup the VLAN configuration on my switch. I have a Ubiquiti Ed...
noisydude
Here is a screenshot of all the configuration options I set
https://www.icloud.com/iclouddrive/0cjAO_yR7xmmE7k-VKBzT0w2A#Netgear_GS108PEv3_VLAN_config
- schumakuMar 31, 2021Guru - Experienced User
Pure simplicity, can't see anything wrong with the switch config.
Just the ubiquitous advise:
- disable flow control (in case it's enabled)
- ensure current firmware is in place -> https://www.netgear.com/support/product/GS108PEv3.aspx#download
- try a factory reset, and reconfig from scratch
