nikhilkale1892
Aug 17, 2022Follower
How to enable dhcp snooping on GS108Ev3 switch ?
Hi Team, How to enable dhcp snooping in model no. GS108Ev3 -8 port switch ? Dow this switch model supports dhcp snooping ? Please let me know how can achieve this in same model if possible.
michaelkenward
Aug 17, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. In your case the GS108Ev3 isn't a router, which is the topic covered in this section.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Apr 12, 2023Retired_Member
