gparkerCOB
Jun 21, 2018Aspirant
how to enable Jumbo Frames on XS748T? Can't find the setting.
I have searched and found a article on the site showing how to enable Jumbo Frames on Pro Safe switches, but the interface in the XS748T looks different than their example and I can't find where to e...
- Jun 27, 2018
Hi gparkerCOB
Sorry for late to back, I missed your reply.
For XS748T Jumbo Frames is enabled by default. You can just use Jumbo Frames without any configurations.
BestRegards
Carl
Carl_z
Jun 21, 2018NETGEAR Expert
Hi gparkerCOB,
Welcome to the community!
You can go to "Switching/Ports/Port Configuration/" There is a value named "Maximum
Frame Size". Just set this value to max to enable Jumbo Frames.
Best Regards
Carl
Netgear Employee
