TheComputerChap
Dec 03, 2018Aspirant
How to prioritise traffic through certain ports? NETGEAR GS728TP
Hi,
A few monhts ago I did setup a GS748T to prioritize all traffic from a specific port. I'm now interested on doing the same with a GS728TP and I'm unable to see the same options. I have look...
- Dec 05, 2018
Hi TheComputerChap,
Welcome to our community! :)
As per checking, these switches has different firmware and hardware models. I double checked the manual and it seems that the GS728TP only supports global configuration and not per port unlike the GS748TP as each port has its own CoS queue-related configuration.
GS728TP:
GS748T:
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Dec 05, 2018NETGEAR Employee Retired
Hi TheComputerChap,
GS728TP:
GS748T:
