mJack1
Nov 14, 2019Aspirant
Increasing Wattage with GS752TXP
I am considering purchasing the NETGEAR 48 port POE Switch (GS752TXP) but need to ensure the switch will offer enough PoE to run my IP camera system. I see the watts provided are 390, divided by 48 g...
- Nov 22, 2019
Hi mJack1,
Welcome to our community! :)
It would be best if you will check first the other model which is the GS752TPP that supports up to 760W. This doesn't have an additional RPS and I believe this can already support your 48 POE devices with 12W :)
John
NETGEAR Community Team
JohnC_V
Nov 22, 2019NETGEAR Employee Retired
Hi mJack1,
John
