PeteCalxx
Jan 25, 2020Aspirant
Is a GS908E a Managed Switch?
The box says "......Smart Managed Plus Switch" but on the, NETGEAR-Product-Registration-FAQ it is listed under Unmanaged switch (87). And what does a Management VLAN mean?
- Jan 26, 2020
Welcome to the community! :)
Thanks you this report. The GS908E belongs to the Smart Managed Plus Switch models. I have already sent a request to correct this article.
The purpose of a Management VLAN is to prevent unauthorized users from accessing the configuration of the switch. You can have at least one port as member of a Management VLAN.
Be informed that the GS908E does not support Management VLAN since it is a Smart Managed Plus Switch. Smart Managed Plus Switch Models gives user the flexibility to configure certain static layer 2 settings in order to improve network efficiency and performance. The configurable features are Port Mirroring, VLAN, QoS, Rate Limit, and Broadcast Storm Filtering.
If ever you want to implement a Management VLAN to your network, I suggest you either of the following switch models below. Click the links to learn more:
Insight Managed Smart Cloud Switches
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Jan 26, 2020NETGEAR Employee Retired
DaneA
PeteCalxx
Jan 26, 2020Aspirant
Thank you.
I have a lot to learn.
