tbrown13
Jan 30, 2022Aspirant
Is it possible to enable telnet or ssh on a MS510TX ?
I just purchased a MS510TX with the intent of using either telnet or ssh (preferably ssh) to configure it. I've done this with Prosafe switches and thought the MS510TX would be perfect for this but s...
- Jan 31, 2022
The shell access isn't intendend for production CLI access, and in no aspect supported.
As usual, you can enable "Remote Diagnostics" via "Maintenance>Troubleshooting>Remote DIagnostics"
Then telnet the manage ip address via port 60000
Works on the MS510TXUP for example, too
schumaku
Jan 31, 2022Guru - Experienced User
- tbrown13Jan 31, 2022Aspirant
Thank you, very helfpfull!
