cos_marchy
Jan 29, 2022Aspirant
Is it possible to setup VLAN in this configuration?
s Hi, I have a GS105Ev2 and GS108Ev3 connected in my home network in the following configuration: and was wondering whether it would be possible to use the VLAN feature to segregate parts of...
schumaku
Feb 01, 2022Guru - Experienced User
The challenge is in the fact that this is not an industry standard 802.1q VLAN config. Muhc more, you need to configure a so-called asymmetrical VLAN, and you have to switches on a trunk config. For simplicity, I suggest to
- VLAN 1 as the normal network (Router on GS105Ev2, Port 1; port 5 for the VLAN trunk), and
- VLAN 2 for the NVR (GS108Ev3, Port 7; Port 8 for the VLAN trunk)
------------- GS105Ev2 GS108Ev3
------------- 1 2 3 4 5 1 2 3 4 5 6 7 8
VLAN1: u u u u u u u u u u u - u
VLAN2: u - - - t - - - - - - - u t
PVID: 1 1 1 1 1 1 1 1 1 1 1 2 1
