jgkurz
Feb 29, 2020Initiate
Is this VLAN config possible?
I am working with a Netgear GS748Tv5 core switch connected to a Netgear GS108E edge switch. On the GS108E I need to assign ports 1-4 to vlan 30 so dumb devices on those ports only flow through v...
- Mar 01, 2020
Of course this is possible.
For the acess ports (on either side, for the dumb devices on the access switch and the port on the biger switch for the router or whatever is serving the VLAN 30), put these on [U]ntgged for VLAN 30, PIVD 30, and nothing for VLAN 1.
For the VLAN trunk - the connection fo the two switches - you can leave the trunk ports the VLAN 1 [U]ntagged, PVID 1, and the VLAN 30 is [T]agged.This is is.
schumaku
Mar 01, 2020Guru - Experienced User
This is is.
- jgkurzMar 01, 2020Initiate
schumaku wrote:Of course this is possible.
Thank you for the response. With your guidance, I was able to get the switch working. Initially I had forgot to tag the trunk port on the edge switch with vlan 30. Now it all works great!
