Vimes
Jan 23, 2015Apprentice
Java, Device View and Netgear GS110TP
Hi Having the device view working (better with IE than FF) with th version 7 Java I am now having issues since it updated to version 8 build 31. all that I get is the small spinning Ja...
- Apr 28, 2015I got a similar issue (http://forum1.netgear.com/showthread.php?t=96318). At least it works with Java 7 Update 80 now. The trick, in my case, was to use the IP of the switch and not the DNS name.
Also Netgear support told me that the Applet is supposed to work at least up to 7 Update 71.
RX
Jan 23, 2015Luminary
:) Hope this helps as a workaround:
1. Open Java Control Panel on your PC then click on Security tab.
2. Click on "Edit Site List" button.
3. Add "https://IP_Address_of_the_GS110TP then click Ok.
4. Click Apply.
If ever the above steps won't work then I guess Netgear should really give attention to this.
4. Click Apply.
