Shikwan68
Apr 02, 2019Star
XR700 doesn't see Netgear ProSwitch GS110TP in Device Manager
I have LAG setup between the XR700 and the GS110TP. The router sees all wired devices connected to the GS110TP. The GS110TP has a static IP.
The GS110TP's IP doesn't show up in the XR700's Device Manager page. Any reason why?
- Do you see the individual devices connected to the switch in the device manager? If so then that's normal behaviour.
- Netduma-FraserNetDuma PartnerDo you see the individual devices connected to the switch in the device manager? If so then that's normal behaviour.
Yes but I thought it was strange as the switch always showed up in the QoS list of my old Netgear R7800 router.
- Netduma_JackNetDuma Partner
DumaOS Device Manager works in a different way, so it's not possible currently.
