Vimes
Jan 23, 2015Apprentice
Java, Device View and Netgear GS110TP
Hi Having the device view working (better with IE than FF) with th version 7 Java I am now having issues since it updated to version 8 build 31. all that I get is the small spinning Ja...
- Apr 28, 2015I got a similar issue (http://forum1.netgear.com/showthread.php?t=96318). At least it works with Java 7 Update 80 now. The trick, in my case, was to use the IP of the switch and not the DNS name.
Also Netgear support told me that the Applet is supposed to work at least up to 7 Update 71.
adit
Jan 23, 2015Mentor
Java issue. It's why Java is dying and things like HTML5 are striving.
The applet was written in an old version of Java. The security of the latest versions of Java break these old applets. I see this all the time with legacy apps.
Netgear would need to rewrite the firmware for the device to use the latest Java or not use Java at all. Old equipment probably won't get updated.
