Vimes
Jan 23, 2015Apprentice
Java, Device View and Netgear GS110TP
Hi Having the device view working (better with IE than FF) with th version 7 Java I am now having issues since it updated to version 8 build 31. all that I get is the small spinning Ja...
- Apr 28, 2015I got a similar issue (http://forum1.netgear.com/showthread.php?t=96318). At least it works with Java 7 Update 80 now. The trick, in my case, was to use the IP of the switch and not the DNS name.
Also Netgear support told me that the Applet is supposed to work at least up to 7 Update 71.
Vimes
Jan 24, 2015Apprentice
Just to add....
Removing Java 8 and then finding an older version of 7.....
gif uploader
.....whilst there are security implications with running older versions, and they are stopping any further updates to the 7 edition shortly, at least it shows that it works.
Netgear I need a fix.!
gif uploader
