Vimes
Jan 23, 2015Apprentice
Java, Device View and Netgear GS110TP
Hi Having the device view working (better with IE than FF) with th version 7 Java I am now having issues since it updated to version 8 build 31. all that I get is the small spinning Ja...
- Apr 28, 2015I got a similar issue (http://forum1.netgear.com/showthread.php?t=96318). At least it works with Java 7 Update 80 now. The trick, in my case, was to use the IP of the switch and not the DNS name.
Also Netgear support told me that the Applet is supposed to work at least up to 7 Update 71.
BlueFlame
Mar 29, 2015Tutor
BlueFlame wrote: Same for GS724Tv4.
Just wanted to add the log file entries for NetGear support.
Log file entries are:
<14> Mar 29 11:18:42 192.168.250.2-1 General[49495940]: web_java_socket.c(5103) 1331 %% Invalid recv datalength.
<14> Mar 29 11:18:42 192.168.250.2-1 General[49495940]: web_java_socket.c(5103) 1330 %% Invalid recv datalength.
