rubrchkn
May 15, 2022Aspirant
JGS524E (Not V2) Web Interface Unavailable
I cannot access the web interface of this switch. I've tried different FW versions. Restored factory defaults. My IP configuration is correct. Same subnet. DHCP is enabled. I can use the config u...
- May 15, 2022
Welcome to the community ! 🙂
The JGS524E switch you are referring to is the JGS524Ev1 (v = version). The JGS524Ev1 does not have a web-GUI. It can only be manage using the ProSAFE Plus Configuration Utility.
The JGS524Ev2 switch can be managed either via its web-GUI or by using the ProSAFE Plus Configuration Utility.
DaneA
NETGEAR Community Team
DaneA
May 15, 2022NETGEAR Employee Retired
DaneA
