ProTofik's avatar
ProTofik
What rack mount kit for JGS524E
Hello,
I have Netgear JGS524E v2 switch which I would like to install in a standard 19" rack.
What is the part number of the mounting kit that I should purchase?
Thanks
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi ProTofik,
    I suggest you to open a chat or online case with NETGEAR Support at anytime to inquire about the part code of the rackmount kit compatible for the JGS524Ev2 switch.
    DaneA
    NETGEAR Community Team
  • Hello,
    I am searching it too. Did you have the kit référence (number) that could fit to this switch?
    • XavierLL's avatar
      XavierLL
      Hi Galmiore,
      As DaneA suggested the easiest way to find the rackmount kit is opening  a chat or online case with NETGEAR Support as finding  stock  could be challenging.
      Regards
      Xavier Lleixa
      CBU NETGEAR PLM
      • Galmiore's avatar
        Galmiore
        Hello Xavier, i do not have an online support anymore (so no chat neither online case if i do understand correctly the support policy)... i am just searching for a reference to order this kit since i have lost it. So not ready to pay an premium support to have this reference :(
ProSupport for Business
