ProTofik
Nov 23, 2017Aspirant
What rack mount kit for JGS524E
Hello, I have Netgear JGS524E v2 switch which I would like to install in a standard 19" rack. What is the part number of the mounting kit that I should purchase? Thanks
- Dec 03, 2017
Hi Galmiore,
You still should be able to open a case through my.netgear.com so our customer support team will help on this . I strongly recommend this as that would be the fastes way to get the rackmount kit.
However I also checked and the part number is 420-10043-01 , you can see the details on :
https://www.netgear.com/business/products/switches/modules-accessories/420-10043-01.aspx
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Galmiore
Dec 03, 2017Aspirant
Hello,
I am searching it too. Did you have the kit référence (number) that could fit to this switch?
XavierLL
Dec 03, 2017NETGEAR Employee Retired
Hi Galmiore,
As DaneA suggested the easiest way to find the rackmount kit is opening a chat or online case with NETGEAR Support as finding stock could be challenging.
Regards
Xavier Lleixa
CBU NETGEAR PLM
- GalmioreDec 03, 2017Aspirant
Hello Xavier, i do not have an online support anymore (so no chat neither online case if i do understand correctly the support policy)... i am just searching for a reference to order this kit since i have lost it. So not ready to pay an premium support to have this reference :(
- XavierLLDec 03, 2017NETGEAR Employee Retired
Hi Galmiore,
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
- GalmioreDec 04, 2017Aspirant
Thanks a lot for your answer it is exactly what i was expecting.
Best regards
Philippe BABILOTTE
