ProTofik
Nov 23, 2017Aspirant
What rack mount kit for JGS524E
Hello, I have Netgear JGS524E v2 switch which I would like to install in a standard 19" rack. What is the part number of the mounting kit that I should purchase? Thanks
- Dec 03, 2017
Hi Galmiore,
You still should be able to open a case through my.netgear.com so our customer support team will help on this . I strongly recommend this as that would be the fastes way to get the rackmount kit.
However I also checked and the part number is 420-10043-01 , you can see the details on :
https://www.netgear.com/business/products/switches/modules-accessories/420-10043-01.aspx
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Galmiore
Dec 03, 2017Aspirant
Hello,
I am searching it too. Did you have the kit référence (number) that could fit to this switch?
- XavierLLDec 03, 2017NETGEAR Employee Retired
Hi Galmiore,
As DaneA suggested the easiest way to find the rackmount kit is opening a chat or online case with NETGEAR Support as finding stock could be challenging.
Regards
Xavier Lleixa
CBU NETGEAR PLM
- GalmioreDec 03, 2017Aspirant
Hello Xavier, i do not have an online support anymore (so no chat neither online case if i do understand correctly the support policy)... i am just searching for a reference to order this kit since i have lost it. So not ready to pay an premium support to have this reference :(
Hi Galmiore,
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
