ifican
Dec 02, 2019Aspirant
JGS524ev2 Loses mgmt ip on reboot
Morning all, have the above switch that simply will not retain its mgmt ip during a reboot. I forgot it was having this issue until i updated the firmware this past weekend. Other then losing its mgm...
- Dec 02, 2019
Your JGS524Ev2 has a config for the managment VLAN?
Again, if you have multiple VLANs and there are DHCP servers the JGS524Ev2 can pick up IP addresses on any VLAN...
No Windows or MacOS system at hand to try the Netgear switch discovery utility? It might be informative for you.
Alternate, check the DHCP server(s) log for assigned IP addresses and the switch MAC.
schumaku
Dec 02, 2019Guru - Experienced User
ifican
Though this doesnt explain the previous behavior it was the current issue. I have since shutoff dhcp and it consistently reboots and has no issues. Thanks for the followup. I have marked the solution.
- schumakuDec 02, 2019Guru - Experienced User
Ok, so a static IP assigned now instead of DHCP - that's about the only solution, indeed. Sorry, missed to mention this opiton.
