sharky696969
Sep 08, 2016Follower
JGS524Ev2 VLAN Problem
Hi, I have Prosage install since 6 month, everything was fine
I have 2 vlan first one for a network 192.168.1.X and Vlan 2 192.168.0.X
the port was assign to vlan 1 but I receive suddenly adress fron vlan 2?
not on all ports but on different port each day is another port give the problem
i have le latest firmware
I have 2 switch and I see the problem on each of one
Hello sharky696969,
Welcome to the community!
That is a weird behavior knowing it has been working fine for a few months. Check your VLAN membership and port PVID settings, (see page 28 of the manual). What changes have you made before experiencing the issue?
Thanks,
- JohnRoNETGEAR Employee Retired
Hello sharky696969,
Thanks,
Hi sharky696969,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
