dumbo25
May 01, 2020Tutor
JGS524PE running v2.6.0.43 with PoE not working
I have a working device that can be powered from other PoE switches. The device draws 5.1v at up to 2amps. It is 802.3af compliant. I reset the JGS524PE to factory defaults, updated the software to ...
- May 01, 2020
My post above can be deleted. I had something set wrong on the device.
dumbo25
May 01, 2020Tutor
