Texarback
Sep 28, 2023Aspirant
JGS524v2 ProSafe Gigabit Ethernet Switch Speed Issue
First, I apologize if this is in the wrong "location". Nothing seemed to fit. Issue: my ProSafe Gigabit Ethernet Switch (JGS524v2) won't allow for speeds greater than about 30-50 mbps. When I r...
schumaku
Sep 28, 2023Guru - Experienced User
Texarback wrote:
When I run the ProSafe program, the switch is undetected.
Not that this does change or magically fix anything: Scratch this obsolete ProSAFE Plus Utility application
(This product/software is end-of-life) and use only the NETGEAR Switch Discovery Tool (NSDT) instead.
- TexarbackSep 28, 2023Aspirant
Sorry, I should have included that I have tried that too. It doesn't detect the switch either.
Could this be a modem or wireless router issue? Regardless of having the switch after the modem or after the wireless router, the switch remains undetectable when I run the program(s). Could it be a CPU issue?
