dtarin
Sep 25, 2023Luminary
LAG/Port-trunk GS516TP to Auss router on Merlin
So I found out the Asus router I have supports port trunking which would allow for more bandwith for wireless clients when doing heavy data transactions on my NAS. (The NAS is already port trunked ...
schumaku
Sep 26, 2023Guru - Experienced User
dtarin wrote:
So is the process as straightforward as setting up another LAG for 2 ports and then connecting those to the ASUS router (configured for port trunking)?
Considering you are talking of these very fast Wi-Fi router like the Asus GT-AX11000 for example, and you have similar fast AX Wi-Fi clients, it's definitively worth the effort to configure and an LACP LAG.
Let us know about your results please.
-Kurt
- dtarinSep 27, 2023Luminary
I activated a LAG in the switch using LACP. Did the same on my router. Connected both ports to the router. That was it. I spent more time crimping a ethernet cable of the right length than the time it took to configure. The port trunking is working just fine.
We'll see how much it helps next time I get a lot of heavy traffic on the wifi accessing my NAS devices.
