McRob1's avatar
McRob1
Luminary
Feb 18, 2017
GS516TP Not Found using Smart Control Center
I am running the latest version of Smart Control Center and when I click on Network and pick discovery after a progesss bar saying it's discovering all devices, nothing is found.
I can link to the GS516TP running the latest firmware from a mac computer running safari with the IP address.  When I try that using Internet explorer V11 on a PC I get the beginings of a login screen that freezes and is blank.
Is there any wat to actually configure this switch on a PC?
Thanks
  • DanneA
    Netgear will only provide support if I give them money on this switch.  I do not have an active support contract.
    Even though this has never worked I do have a work around by using my Mac computer and a browser that can access the switch.
    I don't plan on paying netgear money when I have a method to configure the switch.
    I just wish their software actually worked.
    • McRob1's avatar
      McRob1
      Luminary
      What other web browser would you suggest on a PC.
      I to get to the logon screen and I can type my password in.  The next screen looks like it is trying to log into the switch.  I see the Netgear logo and a logout prompt but nothing other than that with IE 11 and Edge.
      All works fine on the Mac browser.
      I have tried edge without any luck either.
      • XavierLL's avatar
        XavierLL
        NETGEAR Employee Retired
        HI McRob1,
        I would suggest the Firefox portable version as you can run it in your computer , you can download it from the following link
        Regards
        Xavier Lleixa
        NETGEAR CBU PLM
ProSupport for Business
