catadiel
Oct 10, 2016Initiate
Netgear USB control center MacOS Sierra
How about support status for Sierra?
Another project online wich offer similar functionality and suffered the same issues claims that on Sierra's next update (10.12.1 now in beta) Apple has restored all virtual USB kernel api wich means full working support for Sierra.
Are you looking into fixing the software or the support for mac is definetly broken?
We have officially released the compatible software to work with Mac OSX and above.
I would also be interested in a response from Netgear. The software is now useless, as is the company's support pages. The posting regarding the utility and the previous version of MacOS X was closed and marked "solved" without a resolution. A little bit of professionalism Netgear ... maybe?
- raypickAspirant
Netgear seems like the dead letter office. Keeping silent won't satisfy the user community. When can we expect a fix and how will users be notified? Will we have to discover by chance that it has been fixed or will Netgear notify its users directly? This issue leaves some business and home users dead in the water, or with undependable intermittant performance. HELP!
- egbertsGuide
I've just done a fresh install of Mac OSX 10.12 (Sierra) on a Macbook Pro Retina.
Now, I am going to try to install the driver listed on NetGear downnload page at http://kb.netgear.com/app/answers/detail/a_id/27655 .- ElaineMNETGEAR Employee Retired
Hello All, I am still waiting from our engineering team an update about the USB Center Control Utility that will be compatible with your Mac OS.
It's still under SQA, once it has passed that phase I will let you all know.
- kneb139Aspirant
I purchased a model C6300 and tried to install the Utility NETGEAR USB Control Center, it never worked always saying installation was incomplete. Now I've updated Mac OS X a couple times to 10.12.2, and I tried to run the uninstaller but it fails sayig it is incompatible with this version of OS. I would like now to uninstall all traces of the NETGEAR software.
I'm OK with using Terminal if I must.
Can someone please supply a list of all NETGEAR software that I need to uninstall. Or provide a link to an Uninstaller that works.
Thx.
