McRob1
Feb 18, 2017Luminary
GS516TP Not Found using Smart Control Center
I am running the latest version of Smart Control Center and when I click on Network and pick discovery after a progesss bar saying it's discovering all devices, nothing is found. I can link to th...
- Mar 05, 2017
DanneA
Netgear will only provide support if I give them money on this switch. I do not have an active support contract.
Even though this has never worked I do have a work around by using my Mac computer and a browser that can access the switch.
I don't plan on paying netgear money when I have a method to configure the switch.
I just wish their software actually worked.
mdgm-ntgr
Feb 19, 2017NETGEAR Employee Retired
Have you tried other web browsers?
McRob1
Feb 19, 2017Luminary
What other web browser would you suggest on a PC.
I to get to the logon screen and I can type my password in. The next screen looks like it is trying to log into the switch. I see the Netgear logo and a logout prompt but nothing other than that with IE 11 and Edge.
All works fine on the Mac browser.
I have tried edge without any luck either.
- XavierLLFeb 21, 2017NETGEAR Employee Retired
HI McRob1,
I would suggest the Firefox portable version as you can run it in your computer , you can download it from the following link
Regards
Xavier Lleixa
NETGEAR CBU PLM
- McRob1Feb 21, 2017Luminary
XavierLL
I tried Firefox and it does exactly the same thing as IE version 11.
- McRob1Feb 26, 2017Luminary
I was able to get help from another computer expert.
After adding the switch IP address to the compatibility settings in Internet explorer I was able to make it work.
I am still not able to see the switch using Netgears software "Smart Control Center".
Maybe a firmware update of the switch is needed by Netgear?
