tantony
May 03, 2019Luminary
Laptop can’t ping outside of subnet
I have two VLANs. One laptop on VLAN 2, and the other on VLAN 3. I’m able to ping both laptops from router and NETGEAR switch. But, VLAN 2 laptop can ping VLAN 3 laptop. VLAN 3 laptop can’t ping VLAN ...
- May 06, 2019
As suspected, it's a laptop issue. I tried another laptop, and I'm able to ping both laptop to each other from different VLANs.
schumaku
May 04, 2019Guru - Experienced User
There is no "magic" routing between subnets - that's the reason I often say one should not talk of "inter-VLAN-routing". The static IPv4 routing must be configured accordingly. Some routing capability must be avilable on your network, either on a dedicated router, on on an L2+/L3 switch.
- tantonyMay 04, 2019LuminaryThe fact that I can ping the laptops from the router and the switch mean routing works correct?
- schumakuMay 04, 2019Guru - Experienced User
Show us more if your network, of your router configuration (with multiple subnets), and of your switch config.
- tantonyMay 04, 2019LuminaryI’m afraid I can’t do that till Monday. But If I swap the laptops, that’s same laptop is doing the same thing. So it might be a laptop firewall issue. But, I have firewall disabled on the laptop.
