trschell
Mar 01, 2021Follower
letter of volatility - GSS108EPP
Would you have a letter of volatility for the GSS108EPP?
If that is not available, can you post the letter of volatility for the GS108 instead? Thanks!
GS108 is essentially remove power and use Windex.
More similar to the GSS108EPP would by any GS1xxE[xx] - here essentially factory reset is required.
PS. It's crazy what kind of administrative overhead have been caused by this LoV requirement.
- DaneANETGEAR Employee Retired
Kindly download the Letter of Volatility on the links below. Be reminded that the links will expire within 2-3 days.
GSS108EPP Letter of Volatility
Note: The latest GS108 switch model is the GS108v4 (v = version)
If you were able to download the Letter of Volatilities above and you don't have any further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
