Retired_Member's avatar
Retired_Member
Apr 24, 2018
Letter of Volatility for the JGS516PE
I am looking for the letter of volatility for the JGS516PE device. Can you please provide me with a copy of the document?
Thanks!
  • Hi Retired_Member,
    Welcome to the community! :)
    Kindly download the Letter of Volatility of the JGS516PE switch on this link.  The link will expire within 2-3 days.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Retired_Member,
    DaneA
    • DaneA's avatar
      DaneA
      Retired_Member,
      I just want to follow-up on this.  Were you able to download the Letter of Volatility of the JGS516PE switch?
      If ever you were able to download it and you have no further inquiries, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      Cheers,
      DaneA
ProSupport for Business
