jkonz
Mar 28, 2017Aspirant
Letter of Volatility GSS116E
Hello, I am in need of a letter of volatility for a GSS116E-100NAS. Please provide details.
Thanks
I apologize for the long wait. I just received a feedback about your concern on the GSS116E Letter of Volatility. Here is the feedback from the engineering team:
"What is meant is the user can modify the switch configuration or upload a different firmware to modify the content of those memory. Because user can change configuration settings and upload a different firmware image in SPI Flash, the User Modifiable field of SPI Flash is marked as Yes."
"The current letter of volatility is correct and will not be changed."Regards,
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
- jkonzAspirant
DaneA -
Thanks for the reply.
Can you clarify the SPI Flash section under the 'non-volatile memory' section? I am wondering why it is user modifiable without a flash programmer, but in order to clear the device you need a flash programmer. I only ask because this is going to be a problem in our application, I am looking for a clearing procedure that does not involve disassembly or any physical intervention.
Thanks
