tantony
Jul 11, 2019Luminary
Link Aggregation (LAG) question
I never setup LAG before on switch ports, so just to make sure, when I setup LAG, it have to be done on two switches right? For example from switch A and B. If I only setup LAG on switch A what ...
- Jul 11, 2019
tantony wrote:..., when I setup LAG, it have to be done on two switches right? For example from switch A and B.
Correct.
tantony wrote:If I only setup LAG on switch A what happens? My understanding is that LAG is used for redundancy, load sharing, and higher bandwidth.
If you connect two different systems, if you connect a switch using both (non-configured) ports, to this LAG - I'll promise a nightmare and mess on your LAN.
schumaku
Jul 11, 2019Guru - Experienced User
Correct.
